Windows 8 who's buying/upgrading
basically you want look / feel of windows to stay in the 90's?
Windows 7 wasn't released in the 90s, so I'm not sure what the point is you're trying to make?
and please reply saying your a old man and it's difficult to adopt things, that is crap
I didn't say I find it difficult to adapt. I'm all for change if it results in an improvement, but change for the sake of change is retarded, especially when Windows 8 is the result.
I just don't like it. Simples.
if you don't like it. why not customize windows 8 instead of moaning about it?
I didn't like xp style so I customized it with software, didn't moan about it.
it's impossible for MS to make everybody happy, but that's why there's software out there to make windows the way you want it
Gareth, there seems to be quite a lot of people who don't want to adapt as things more on. Even my wife won't have Windows 8 juts because 'its not intuitive' though quite what that means I have no idea. She has Office 2010 and turns of the ribbon - one of the best ideas in Office for years.
Adapting to new things is something some people can't cope with. Oh, and I am a wheelchair user so I have to adapt to lots of things over time.
Because I shouldn't have to install something to make it work the way it should work by default. I really can't think of another way to make that clearer. As I posted earlier, if they had left the Start Button alone then I would ignore Metro and use W8 quite happily.
And don't be rude, I'm not moaning I'm complaining. You cannot expect every post in this thread to be positive ones from Windows 8 fan boys.
Yes, because it gives access to so many 'under the hood' components that I use extensively, especially when setting up a new PC. I couldn't work out how to get to Control Panel for love or money. Yes, I could have Googled it, but why should I? If it's not intuitive then it's crap IMHO.
Your thought process should have been as follows (and I'm not being unreasonable here and making it anything out of the ordinary):
  1. Realise you can't find the control panel because it is not where you expected it to be, and that to "find" something you must first "search" for it.
  2. Invoke the charms (this is explicitly referred to as the new way to use Windows and repeatedly demonstrated before you sign in)
  3. Click on the magnifying glass (this is labelled Search)
  4. Type in "control panel" as your query and/or pick out the icon labelled "Control Panel" in the list
This is a good example of an intuitive system. You gain knowledge through small intuitive steps. We completely gloss over the fact that we already know what a "control panel" is and that a rectangle with a blinking cursor is a prompt to type in your search query. That's intuitive to you now, but you were not born knowing it.
I'm not "picking" on you as such, I'm just quoting you as an example. It's been said countless times that Windows 8 is not intuitive, but what people really mean by that is they expected to be immediately proficient in a completely new system. Which is, of course, absurd.
or just press the windows key then Type in "control panel"
same had you can do with the start menu
Just downloading it now. It does not give you an option of where to download to, so where is? Non of my hard drives are losing space.
Is it just replacing files with the new ones?
When its downloaded it will give you the choice of making a bootable USB or an ISO you can burn to a DVD.
You can actually do both if you make the DVD first, then quit the upgrade, then restart it and select USB this time.
That would be absurd, but immediate proficiency wasn't my expectation. Intuitive = logical and obvious (visually and mentally). W8 isn't to me. Failing to have a tile for Admin on the tiled screen is a fail IMHO. They have tiles for all sorts of completely irrelevant crap there, but omit that. Moving my mouse to a corner of the screen to make the magnifying glass isn't intuitive or obvious.
Or if your on the desktop, you could go to the charms bar and click settings which is where direct access to the control panel is hiding (and it took me a few days to find that out).
The only annoying aspect for me is that the Metro Apps if launched keep my GPU running at full clocks.
Took me a while to figure out why it wasn't downclocking.
Allied to this, you can close one app by right clicking the top left corner of desk top but if multiple Metro apps are launched at the same time, the only option is to kill each app individually in Task Manager.
For me, the simplest course of action is to just have a Desktop link on Metro and use normal (Windows 7) style desktop 100% of the time.
As for not having a start button, simply not an issue:)
Shortcuts to Task Manager, Control Panel etc are placed on the Task Bar resulting in zero loss of functionality.
Simples:)
Cheers.
Appears I just installed it straight off so assume have no backup of it if needed?
Simples:)
From all the people that whinge about the start button, I find it so hard not to think of...
Not a fan of this Metro and all that horrible crap it comes with. Had to pretty much uninstall as of those stupid 'apps'.
Upgrade was pretty easy though am having to reinstall the Comodo firewall and my graphics drivers.
Simples:)
Just drag the app from the top centre downwards, as if you were throwing it on the floor. Closes the app. Pretty simple.
