Morning emergency. Toilet tank lid broken
Caporegime
18 Oct 2002
London
**Inconvenience - toilet tank lid broken**
Not the best start to the morning. I accidentally broke the lid for the toilet tank. Suffice to say I know nothing about toilets. The lid has a hole in it for you to push the button. Where can I buy a cheap replacement? Many thanks OcUK.
I think you'll be lucky to get a replacement for that nearly 5 years after it was made, I think you'll have to go down the new cistern route to be honest.
I wouldn't want to be the person going in there after him...... His morning deposits are strong enough to break toilets! :p
The lid is in pieces on the floor, thought a picture of the button mechanism would be helpful as it goes through the lid. Where do they typically put the model of the a toilet? Does that say "1G" in the picture - is it of any significance?
Thank God it was just a very minor "dropping the kids off at school" - that toilet has caught me out badly in the past!
It isn't nearly as bad as you might think. The toilet takes an age to fill the tank back up (this is where I have been caught out in the past). My house mate had used the toilet just before me which I did not know. So I went for a quick poo, flushed and nothing happened. As I was in rush I decided to fill the tank manually, lifted the lid and forgot it was on a cord because of the button. As soon as the slack went I dropped it and it smashed cutting my hand.
How on earth have I just bought a i5-3570K - a highly engineered piece of tech for £170 and a cistern lid can come in between £150-200!!!!?
