- 15 Aug 2007
- Outside in the bushes
Rule 2. Double tap!
Yes by pouring a bucket of water in it, why does that seem so strange?
So I went for a quick poo, flushed and nothing happened. As I was in rush I decided to fill the tank manually
Do you keep a bucket close at hand for such instances?
Surely if you would have spent more time 'crafting' your item then it would have re-filled.
In my rush, no I didn't as I have always filled the the tank of a toilet in the past.
Seems a bit pointless, pouring water into the tank to then flush it, you do realise how toilets work right?
Well here's a clue, the force of the water rushing in to the pan takes the waste away, so chucking water down the pan, works exactly the same.
It's not really very 'intricate'.
The water goes from the tank into the toilet.
Thank you. I always thought you put it in the tank. Any way moving on from my lack of knowledge of toilet flushing.
