Yes ! Beta 13.2 drivers even more so.
I agree ! getting the same performance as 12.11 & 13.1's but Skyrim & FC2 whoa .. difference (for me) is amazing !
Thanks for the update tommy. I'm sticking to 13.1 WHQL as they seem very stable until the 13.3 beta's are released.
matt, not ready to really get into FC3 yet as I need to finish other titles first so the checkerboard bug(on Tridef-it's fine on 2D) hopefully gets addressed or Ubi fixes it as it only started on the last patch.Have they bothered to fix HDMI audio? I'm on 12.11's and losing hope.
Looks good to me. Did you fix the crashing issue bor?
Hi I haven't reinstalled RadeonPro yet just afterburner I will try soon as thanks
Andrew D @CatalystCreator
Quick update - Catalyst 13.2 Beta driver will now be likely releasing next week
Snip
Will wait for the "official" release of the beta before going to it myself. Looking forward to it though, hopefully they include some further fixes for other games they might have tested![]()
I'm using 13.2 now, seems smooth and stable. 13.3 is what i want though.![]()
Did you remove Caps b4 installing these or did you just install
over the top?
PLUS OTHER GOODIES INTENDED FOR THE REAL 13.2 ARE MISSING.
Just in case you've installed the latest Beta and are having issues
THE LEAKED BETA 13.2 IS AN UNFINISHED DRIVER SPECIFICALLY DESIGNED
TO TEST FRAME LATENCY, WITH NO FINAL QA COMPLETED ON ANYTHING ELSE
IN THE DRIVER. PLUS OTHER GOODIES INTENDED FOR THE REAL 13.2 ARE MISSING.
DO NOT INSTALL IT."
The above is taken from Overclock.net post 1797
http://www.overclock.net/t/1318756/amd-12-11-beta-drivers/1790
