I received my Benq XL2411T yesterday and have noticed very faint lines running horizontaly across the screen from the top all the way down to the bottom. Anybody any idea what is causing this & how to sort it out.
Thanks.
Will try a new cable.
The cable i need would be a DVI-D Dual link or a DVI-I Dual link?
No i'm connecting via the supplied dual link cable.
What GPU are you using and do you observe the same at 120Hz rather than 144Hz?
I observed something similar when reviewing the monitor. I think it is some sort of bug with certain settings. In my case it went away after fiddling with a few things and it only affected the far left side of the monitor. Try disabling `Instant Mode`, turning the monitor off and on again. See if you still see this pattern. Enable instant mode again if you like.
Just put it in 120 instead of 144 seems to have sorted it
It seems to be a trait of all BENQ XL2411T monitors, to varying extents, and worse during LightBoost mode. I only see it during LightBoost mode, and mainly in the upper-right area, but very faint and not noticeable at normal view distances, especially when playing games.I received my Benq XL2411T yesterday and have noticed very faint lines running horizontaly across the screen from the top all the way down to the bottom. Anybody any idea what is causing this & how to sort it out.
Thanks.
