- 23 Apr 2012
- Edinburgh
The pin outputs on the board marked as xxx_Fan are simply fan power headers, they will not all necessarily have something attached.
It sounds possibly as if the CPU fan is catching on something if it's THAT loud - even at full speed the Alpenfohn would be more of a whine/whoosh than a grinding sound.
With the power disconnected, see if you can manually spin the fans in your computer - try both the CPU and case fans and see if they are spinning freely without noise
