the bios flash should have worked![]()
you just put the bin file on the usb stick? and its formatted to fat32
read load's of review on this mobo and all say its a good one
the freezing issue is the only one I have... but it renders the system pretty useless
Loads of threads on different forums having the same problem.. I wish I'd gone with something different
now running F19g...
will have to wait and see if it helps
freezing is usually ram related,idk what to suggest,either rma the board or memory or try n borrow another set to test,im using samsung green and its fine
you could email gigabyte uk and ask them if the board supports geil 8gb,tell them the model number and ask if they could send you a custom bios to try
Currently running on some old 2gb sticks (4gb total) not sure about the specs really as they came out of an old Acer desktop..
been running fine for about 2 hours.. but it's been longer than this without freezes before so doesn't necessarily mean it's sorted yet..
any news on this?
