It seem's like i've hit the wall on what my card can do now. its taking quite a lot of volts to get not a lot of MHz. i cant get much above 1200core stable on 1.3 and AB wont let me go higher (along with my wallet).
@Gregster take a look at post 728. it got me back into 3rd on top 7950 scores (just), but it'll be the last from me.![]()
Whats your asic's quality on your 7950 and is it a 8pin 6 pin version?
More low to midrange cards should enter, as its all mainly all highend..
People can check to see if their cards are performing properly if we had a decent number of people entering with low and midrange cards. Come on guys who cares about high scores![]()
66% and its an 8+8 card but i've only got 8+6 connected, the second pci-e cable is only 6pin.
When I first moved from Nvidia to AMD I was told that over 1200core you needed to mirror the voltage 1/1 as in 1.2v for 1200core etc, and this may hold true for lower asic cards like yours but have you tired to run 1200 sub 1.162v?
Kamz
Greg, could you double check my scores/results Post #721
The cpu is @4.5 not 4.2 as listed and i may be one place on board above where i should be.
Thanks![]()
Will sort that now Rich![]()
Core clock at 1270 going by 3D Mark BodgeIT!
One done at 1280 now but well spotted.
Score 8742
http://www.3dmark.com/fs/122037
7970 @ 1280/1870, volts 1287 & i7 990x @ 4.439mhz
Graphics Score 9566
Physics Score 15139
Combined Score 3835
Nice one![]()
Cheers.
I have hit almost my maximum now I think. The Cpu won't go much higher without water, due to temps and two attempts at 1300 told me to stop being silly. 3rd time lucky?
I'll stick the 7970 back in the machine again at some point and have another crack at it. Only gave it quick run.
