There are two cracking ones in the network at mo. One comfort with fatboy seats and one comfort with buckets. Seem good value but I don't think I have the brass to stretch to it. Guess I need to go chat with them
Found a 2008 997.1 C2S with x51, Chrono, PCCB, Sports Suspension, PSE, PCM. Very high spec, I expect rare, and perfect for me with 40k miles. Just concerned about life of PCCB rotors at a rumoured £20k replacement cost. Anyone ideas on life expectancy? And also can I get an OPC warranty on a car sourced elsewhere?
EDIT: just checked the price to replace with steels and about a grand, that is if the calipers are same.
Got a link to the car you've found?
PCCB will last over 100k+ miles if your not tracking car, the 996 GT3 for sale at moment with 185,000 miles is still on it's original PCCB disc and they are the older gen1 type disc, 997 cars have gen2 disc.
To convert to steel all you need to buy is 997 turbo steel disc which cost sub £800 from OPC for entire set and that's all you need.
As to warranty, two options, ask the seller to put a warranty on the car for you and pay the extra or after 90 days of ownership you can take it to an OPC for a 111 point check and then purchase a warranty.
Do it!
