F1 Technical discussion
Man of Honour
29 Jun 2003
Wiltshire
Cheers for the link on the Drag Reduction System Duke. I must admit to understaning the principle, but not being able to figure out in my head how it was actually reducing downforce. Luckily that pic with the flow vis shows it perfectly. The airflow up the periscope detaches the air from the underside of the rear wing, meaning the area affected doesn't produce (as much) downforce or drag.
For anyone else who needs it, basically the triangle bit inside the green circle that doesn't have much flow vis on it is not producing downforce or drag. While its not a massive section of the rear wing, it is still a sizeable chunk of downforce to loose.
Coanda exhausts explained...
Edit - lol - the forum edits out the letters Q F T which are part of the URL :rolleyes:
Click the link and replace the 3 stars in the URL and it'll work.
I can't get that link to work. Is it this video?
