2500k@ 5.0
GTX680@ 1320 core 1640 mem
And also post the classic shot of your results in front of the cobbles
Also your CPU and GPU type and clocks
chris what voltage you running at for 1150/1500 i'll try with my 3570k
May want to put this part in bold lettering mate.
Rated the thread also, good work so far Kaapstad
Here my result:
GB WF3 GTX 670 SLI
1200/1800 @ 1.21v
2700K @ 4.8
You need to rerun with 8xaa to get on the score list or were you trying to ninja yourself the top spot lol.
What sort of voltage are you guys using to get the big clocks on 7950/70s? I'm never sure where to stop, voltage wise, with GPU OCing.
As much as the card will take which is about 1.365v. When I tested it with the stock cooler I don't think I went above 1.3v as temps were getting out of control. Mines under water now though so I have no problem with temps.
