Bro I've always mired your wheels. Awesome mass and even being able to see those lines when you're this fa--, higher body fat, is awesome.
careful now sweet cheeks!
Hammer Strength ISO Chest Press
120KG x 9, x 5, x 2
Chest stretch - 22.5KG DB's
This working weight was slightly too heavy as I fell for 4 reps short of the minimum (20, 20 - 30 target)
Hammer Strength ISO Shoulder Press
70KG x 8, x 6, x 5
Shoulder stretch
This was too light, surplus of 4 reps over the target maximum (15, 11-15)
Bicep Stretch
GCBP had a spot for these and did require a spot on the last reps of the last two sets.
80KG x 8, x 4, x 3
Tricep stretch, 20KG dumbell. Bang on the maximum reps for this exercise.
Hammer Strength ISO Pull Down
120KG x 8, x 4, x 3
Bodyweight hanging Lat stretch 2 x 30 seconds.
BOR - WG Straight Set - middle fingers on the smooth rings of the oly bar
80KG x 10
Improve ISO back stretch.
Grip was the limiting factor on this due to the forearm pump for the lat stretch and also wide grip. Will strap up for these next time.
ye ye..i know that. I just think that some of these high intensity programs are more geared to the anabolic types. be interetsed to see how it goes for u![]()
i realy loved doing the yates style HIT traiing a few years back..but its only good if you lifting some decent weights first.
Preacher Curl rest pause
30KG x 12, x 8, x 5
Bicep stretch.
BB Reverse Grip Curl straight set
15KG x 15
Bicep stretch
Standing Calf Raise (smith) 5 - 15 - 0
40KG x 10
No stretch required.
This was a bit of a mistake, through choice, and the rep method should have been a straight set, makes sense as a greater load is required. I won't use this method again and will stick to it just once a week in a seated exercise.
Leg Curl
45KG x 9, x 6, x 4
Hamstring stretch
Back Squat Straight set, widow maker
150KG x 7 (PB for reps) - obligatory, one fiddy.
110KG x 20 (17 / 3)
Lots of quad & leg stretches.
Little bit disappointed I had to rack and recover. I should have rested longer and attacked the set with a different method. I was hoping for 3, 5 rep bursts and to then grind the final 5 out. However I got to 8 and started grinding out singles taking to long between reps so got gassed a bit to quickly. I was spitting all over the mirror and caked in sweat. I took 10 seconds to pull myself together after rep 17 to crank out the final 3.
Glutes feeling veryyyyy tight tonight so will stretch them endlessly tonight. Quads feeling surprisingly fine.
Bro they're some brilliant squats, 7 reps at 150kg is pretty beastly. Not quite so sure if I'm as impressed by 110kg @ 20![]()
Decline Bench Rest Pause
120KG x 3 / 110KG x 4, x 3, x 3
20KG DB stretch.
This was too heavy, well I actually started my work set with 120KG so probably would have hit the rep target of 11-15 on this if I hadn't have done 3 @ 120.
Decline feels like a very small ROM and not particularly beneficial but will stick with it as sooner or later I'll miss reps and switch it for something else. (As this is the first week and I'm still finding my working weights nothing will be dropped yet)
OHP Rest Pause
60KG x 6, x 3, x 3
Shoulder stretch
EZ Skull Crusher Rest Pause
27.5KG x 13, x 7, x 4
Tricep stretch 20KG DB
Chin Up Rest Pause - supposed to be close grip but ROM is too small due to my ribs/lats getting in the way so used shoulder width grip.
BW + 5KG x 8, x 4, x 3
T-Bar - close grip row handle Straight Set
80KG x 6 70KG x 5 (6 @80KG - bit ambitious)
Improv rhomb stretch.
