Road Cycling Essentials
Status
Not open for further replies.
Discovered light weight inner tubes today lol.
Weighed all mine up. Regular tubes seem to be around 98-103g & the light weight ones 67g. 31g saving per tube not to shabby!
Has he just created it?
It will retrospectively go through your rides and add you to new segments that people create after your ride, but sometimes it takes a while for that to happen.
So you might find that you end up on top of that segment soon, or you might have to go and beat him.
He is top and i'm 3rd.
Latex rather than butyl?
Less hysterisis (sp?) as well so fewer lost watts. They loose air quicker though.
Apparently they're still butyl even come pre-talc'd!
Specialized Tube - Turbo Ultralight Road Tube with Talc
The Turbo Ultralight road tube, with new patent-pending valve and valve base, is proven in rolling resistance testing to reduce drag by as much as 13% per wheel.
> Talc in the pack for a better ride and fewer flats
> Large 4.8cm base prevents wear and tear on the rim-to-valve interface
> Threading only at bottom half of valve stem allows secure fit to rim
> Presta Valve only, smooth at the top for easier pump head insertion
> Thinner tube than our standard tube saves 40 grams of rotating weight
> 0.6mm thick
Yeah I love it, although cant stand getting a KOM taken off me, so if it happens I do tend to go out of my way to try and get it back.
same here! :) i love it.. makes me push harder which is always good! got one KOM afaik.. the guy in front was in a car or motorbike.. with average speed of 28mph and 52 as max.. :rolleyes:
I know 2 people that have recently gotten their first kom. I'm finding it so hard to fight the urge to go sprint them specifically to steal them.
Went with
V-Sprint Track Wheels - Miche Hubs - £134
Great value, great wheels, super smooth Miche hubs.
Specification
32 Stainless steel spokes - (black or silver), radial or 2 cross front
Large flange hubs (Available in black or silver)
Double sided rear
120mm standard track rear wheel spacing
DP18 30mm rims finished in stunning gloss black, silver, white or yellow with machined braking surface
Double section aluminium alloy - 700c x 18c - 23c
For Clincher tyres only
Looks pretty good and the pricing is perfect.
^ I had wheels from v-sprint before i upgraded to DA hubs.
Built by mr varnish himself (father of now well known olympic track cycling, jess varnish)
Status
