Got my seatpost, saddle, stem, bars, levers and clip on mudguard robbed last night outside the pub
what a real pain in the ass, pub was really busy too and there was atleast 10-15 bikes also locked up that had nothing stolen
[Damien];23848350 said:I'm going to have to pick up a turbo when I've got some disposable cash. Thinking about it though, surely the fatties have the advantage in stationary cycling. They're likely to have far more power due to having to drag their relative bulk about on a day to day basis and can put it all into the pedals without having to take on their usual enemies, namely mavity and wind resistance.
[Damien];23848623 said:How you finding the gran fondo? If I had some cash lying about I'd definitely pick one up just on the looks alone.
Here's a quick shot
Is anyone here what they would consider an experienced wheel builder? Struggling to decide how to lace my rear wheel when it arrives.
I'm thinking two cross drive side, radial non drive side. It's a 28 hole 50mm carbon tubular rim if that makes any difference.
[Damien];23847579 said:That's pretty cool. Which hill is it?
I wouldn't say experienced but I've built about 10 wheels. I've seen radial lacing on one side of the rear wheel but you shouldn't really do it. The torque of your pedalling through the hub tries to turn the spokes in the wheel so I'd always cross-spoke the rear on both sides. At the front it's fine though, as long as the hub says it can take radial spokes. Remember the forces are a lot higher on radial spokes so the hub has to be stronger and you're more likely to break a spoke. Two cross is also a bit on the weak side for a drive wheel - I've always gone three cross on both sides and you get a nice tight strong wheel.Is anyone here what they would consider an experienced wheel builder? Struggling to decide how to lace my rear wheel when it arrives.
