A3 6/3/13
Decline Bench - Rest Pause
110KG x 7, x 3, x 2
Chest stretch 22.5KG DB's
OHP - Rest Pause
62.5KG x 6, x 3, x 1
Shoulder stretch
EZ Skull Crushers - Rest Pause
32.5KG x 13, x 7, x 3
Tricep stretch 20KG DB
CG Chin Up - Rest Pause
+6.25KG x 9, x 3, x 2
T-Bar Row - Straight Set
70KG x 11
Rhomb/trap stretch
Considering decline bench should be my strongest angle it really isn't! or at least doesn't feel it! :/
I'm fairly certain I'm not eating enough, in fact I know I'm not because I'm not particularly happy with my fat levels at the moment which is making want to not turn my body into the 'furnace' the program dictates your body should be and is probably having a detrimental effect. The carb phobia I have is partly the cause and I hope the change I'm considering to my diet will address this (below).
That said in some areas I seem to be making reasonable progress, possibly due to the exercise variation & associated benefits and in others I seem to be strugling, sometimes with the weight progression and othertimes with the exercises themselves.
I really struggle to focus on any delt activation at all during OHP, despite using the method rippetoe teaches, moving under the bar etc unless I use a static hold & squeeze at the top. I have reasonably decent shoulder mobility but just find once the bar gets past the top of my head it feels like my triceps are taking over completely.
The CBL (Carb Back Loading) train that has been taking the SA by storm has taken my eye and as I seem to get on well with IF I think that I could get on well with it too, as it is just a modification of carb timing, volume & sources.
I will get some progress shots up tonight. I really do think you need to be eating like a fat monster and perhaps be 'assisted' to make the most from this program. With the possibility of a summer holiday looming and having already started at a higher bf% than I'd have like my goals have changed somewhat and now dropping fat & maintaining my size and strength (if possible, as CBL boasts, increasing them) are the priority rather than strength and consequently size.
My mind is pulling me in all different directions, towards HST again, but I do like the variety and intensity of DC but it's perhaps not the best choice for me at the moment.
I will finish another complete cycle as I think there is progress to be made still but after that I'm undecided.
I'm more a fan of daytime shots as my anabolic lighting is just highlighting the fat/water I'm holding:
My back has thickened up and I'm certain the extreme stretching has improved my chest definition/shape significantly but it's all hidden at the moment
looking back over my IF/HST journal has just concreted that I need to drop around 4-6KG.
