- 25 Nov 2011
- Hastings
^^^^^^^^ the truth, all the rest are lies.
think of all the porn you can download overnight!!!![]()
personal choice though really,turn off if need be
electricity isnt a problem if all the power saving is enabled on your pc,helps lengthen the life of components also as they arnt running full pelt all the time
On? Off? Why not just put it to sleep?
Putting it into sleep uses about 90-95% of the power when on.
The only reason I turn mine off, is bad past experiences with harddrives not spinning up when cold booting in the morning. I was very lucky to get my files back (persistance), and for that reason would rather keep my PC on 24/7 than lose my data.
And there's nothing worse than cold fan bearings grinding away in the morning.![]()
