use a vpn when then restart origin and you can launch it, then close VPN and download the full game, then spend ages trying to get into it
i have origin version and even a VPN worked so should do for everyone now
Cheers mate - which VPN did you use/recommend?
Presumably when the UK servers go 'live' at midnight then a lot more 'space' will become available, and it should be easier (and quicker) to download whatever is initially required... or doesn't it work like that?
There are no UK servers its EU East & West 1 & 2 and at the mo they are full
Patch 1.2
* Fix for crash caused most commonly occurring on servers experiencing lag. This crash would happen most often when claiming a new city when playing in a region.
* Fix for server select dialog not appearing on start-up if the server the player was last on is not available.
* Disabled Cheetah speed. Cheetah speed is is now the same as llama speed.
* Crash fix for finding closest points.
* Crash fixes in transport and pedestrian code.
* A fix cities having processing problems associated with helicopters.
http://forum.ea.com/eaforum/posts/list/9341807.page
I have read none of this thread, no reviews, nothing on the official site.
I have played a couple of hours so far and I think the game is great.
