Just about able to be maxed with 7950 CF at 1920*1080 with 60 FPS (although I play on a 120 Hz screen). SMAA 4x more than halves my FPS over FXAA.
What drivers are you using Rusty?
13.2 beta's - thought I was using old ones but I'm not. Probably beta 3 or 4. Can't remember.![]()
Nice scores tommy yeah i had the single digits fps thing, must be a bug.
I only get crashes when I have TressFX on. Otherwise I'm getting near 60fps
im getting close to 60 average in 3d with everything on max except for TressFX which is off and using FXAA instead of SSAO
Don't know about you, but this is a showcase for 3D mate, simply jawdropping when you start taking control of Lara at the beginning.
Great isn't it. The hair looks messed up for me in 3D but no probs with normal. Is it the same for you or does it look good?
Just did a quick benchmark run on my 7950 at 1175/1500 on the Ultimate graphics preset at 1080p.
Also getting the minimum FPS bug, didnt get a single stutter during the benchmark though.
