SimCity V (2013) - screens/artwork and information
Quite simply, slowly.
I hold back on services for as long as I can and only place the minimum to keep the place from going crazy. Even better if you have a nice neighbour get them to 'babysit' your city while you build up the profits to have your own.
I actually start my cities by roughly drawing out areas where I want things using basic roads (cheap and cheerful and can upgrade later). For example my last city had large ore and coal deposits so I drew circles using the roads around the richest parts. This marked my money areas which I filled with industrial zoning for the meanwhile. I then connected all the circles with again small roads (wont need anything large for now) and then made some sections where I thought was best for residential and commercial. I just pumped in as many as I could then.
I ignored buying utility buildings and bought them straight off my neighbour. You pay peanuts for them (a little more expensive htan your own yes) so its no biggy. Also I HIGHLY recommend you send waste (not garbage) to your neighbours where possible until you can afford a treatment plant. My reasoning for this is simply because the pipe thingies turn the surrounding ground into a hellish polluted mess which highly decreases the land value and takes an age to clean up. Sending your filth to your neighbour for a few bucks far outweighs spending a couple of hours in cheetah mode trying to clean the damn mess up.
Also its nice if when you build the services to send them off to help neighbours. They dont pay for it but you still get something back for it (apparantly). I do it mainly because im nice like that.
Its worth noting that if you have 2 police cars and assign both to neighbouring cities it DOESN'T mean you wont have any in your city. It basically means that when the need arises your cars will go to them and thus leave you without those cars for that short period of time.
thanks;)
Is it possible to restart a claimed city ?
Not here yet, I don't actually have to be on my city do I? I've loaded the server but just at the main menu.
You need to accept his Origin friend request first I think so he can then invite to region?
Press shift + f1 to access origin menu in game
