***ArmA 3 Thread***
Just played for the first time with graphics settings on autodetect, it ran smoothly enough, just need to work out what all the buttons do, it seems this game uses every key on my keyboard :D
Me and Dave beast getting REAL close
Every key on the keyboard has a normal, shift, alt, and alt shift combination. Especially if you start getting things like ACE mod :D its awesome, finally getting my moneys worth from my keyboard ;)
Game is busted, every server you turn into a seagull.
Can't join ocuk server, does not show the screen to choose team and then it fails when loading mission file.
Have you opted into the beta on steam ?
Can't say i've had any issues with seagulls since opting in. Just been playing on the MGT/OcUK server with no problems.
Have to say i'm surprised at how good the performance is on this, getting at least 50 fps up to about 75 at peak, with an i5 2500k @ 4.6 Ghz, 8gb Ram and a GTX 580, at 1920 x 1080 with most setting at high or very high, have only turned off post processing and dropped AA down to 2x, still looks bloody awesome.
Beta affects performance
I've been trying to play this tonight, all different servers, wasteland and death match. I keep getting turned into a seagull, any ideas why? Do I need to opt into the beta?? Thanks
According to new reports for the seagulls, it's either wrong version on old servers OR people using a pirate edition, so some form of protection.
However since rechecking my files, I haven't seen that problem since. Could just be version missmatch problems
I have down loaded this tonight but ran out of time to play and I'm away with work for 2 days now :-(
I like the helio Training mission ......
lols
seagull means you have joined a coop server picked a slot that has been used and the character is killed and there is no respawn on the mission that is playing
