I think it only stabilises it for a few seconds, you sure you're kneeling or prone if possible?
Yaeah crouched.
thought that there might be a specific key.
Just played for the first time with graphics settings on autodetect, it ran smoothly enough, just need to work out what all the buttons do, it seems this game uses every key on my keyboard![]()
its awesome, finally getting my moneys worth from my keyboard
Game is busted, every server you turn into a seagull.
Can't join ocuk server, does not show the screen to choose team and then it fails when loading mission file.
Have you opted into the beta on steam ?
Can't say i've had any issues with seagulls since opting in. Just been playing on the MGT/OcUK server with no problems.
Have to say i'm surprised at how good the performance is on this, getting at least 50 fps up to about 75 at peak, with an i5 2500k @ 4.6 Ghz, 8gb Ram and a GTX 580, at 1920 x 1080 with most setting at high or very high, have only turned off post processing and dropped AA down to 2x, still looks bloody awesome.
