Do you record to the hard drive you're playing on or a separate one?
I play on my SSD and record onto a different hard drive
If you wish to support the server, join our forum.
www.mgtrolls.eu
There is a donation link at the top, thank you in advance.
www.mgtrolls.eu
I have had three crashes of arma 3 is not working. Has anyone else had this today or do you think a steam integrity check is in order?
Edit: It's ok I think the server went down.
Is there a KEY to press to hold your breath so as to steady your aim ?
Has anyone come up with a solution to the low GPU/CPU usage but low framerate issues? It's very widespread as a quick google will show and there are several large posts on the official forums about it but I can't find any concrete tips to help with performance. Changing settings from Very High/Ultra to Low results in only a couple of FPS improvement. I've only tried the helicopter and infantry SP missions with the helicopter one decimating my framerate to below 20fps. The infantry one isn't as bad but doesn't really get over 30fps. I haven't tried online yet as the only server I tried got stuck on waiting for host after it got the mission files.
I've tried the -cpuCount=4 in the startup options but that didn't help.
PC specs:
Q6600 @ 3.4ghz,
4GB DDR2 @ 900mhz,
GTX 470 @ 800/1800 (roughly, can't remember the exact OC)
Windows 7
Game installed on an SSD
PC specs:
Q6600 @ 3.4ghz,
4GB DDR2 @ 900mhz,
Windows 7
