I'm going to get bt infinity - I assume my blops 2 experience will be even worse ?
Since you rarely play it then I would not worry about it.
That is highly likely especially if you get host more.
none of the purchases are game breaking or really give advantages.
How long before that changes though? They already introduced the Peacekeeper gun in DLC which a lot of people initially said was overpowered (I don't actually know as I've never used it)
I'm tempted by the 10 CaC slots.
What does it actually give you though? Looked at it in game and was confused how many it gives you.
1. You can create a name for each of your class sets.
2. The maximum number of customer class slots per set is 10, but only if you have prestiged enough to unlock all of the 5 custom class slots. I currently have 2 extra slots, so my total is 7 slots per set, times 10 makes a total of 70 class slots.
3. In the class modification screen, you use the bumpers on the controller (RB,LB) to toggle/scroll to each class set.
4. It appears that you need to commit to one class set before you start the match. For example, if you know you are playing a free-for-all match, then you will want to pre-select your class set for FFA matches. You could do the same for Domination, etc... or whatever you like.
I'm getting so tired of seeing kill cams where they see a second before I see them, absolute joke.
Last night was shocking for bad connections, nearly every game was against the french and they would always pull host.
