Permabanned
- 19 Jul 2012
- Buckinghamshire
My temps went up to 80c on heaven. I had to up the fan speed a little to keep them down. After that my temps peaked at 67c.
The standard fan setting 30% and the same from Idle - 80c
Just make a sensible fan profile in PrecisionX and you won't have to worry again.
Temp- %fan speed is a starting point so 60C= 60% fan
What boost do you get guys when temp at 80 C?
Mine seems to be a bit low 836-849 MHz - is it right?
Mine does 993 MHz when temps at 77 C so look ok then.I never run GFX cards that hot,but at 60-65c you should boost to around 1000mhz, that may be the case below 70c.
Also remember the temp target will slow the card possibly before even ramping the fan.
Mine sits at a twitching 996-936 in an air starved 800D while still waiting on my block as an idea so something seems a tad out to me there.
Doubled up.
Will double check in a bit, but its usually sat around them clocks and isnt in the best of cases for airflow.
As for OEM coolers apparently an accelero one was in the works somewhere wasnt it?
can I check whether all the Titans currently out are reference spec so that in the future if I was to get a waterblock I wouldn't run into grief?
I'm thinking of getting the EVGA one.
There wouldn't be any issues with putting that under water later would there?
Yep, all Titans are reference spec and any of the Titan specific waterblocks will fit
Stick with EVGA as well for water cooling.
Just ran this @2560 x 1600
Huge improvement in scaling compared to 1920 x 1080
you should see the scaling at 7680x1440![]()
