- 22 Jul 2012
- London
You'll see, my friend. You'll see...
it surprised me,its actually better than crysis2 and I agree petey it looks amazing
I only played Crysis 2 on xbox and got bored out of my mind. Never finished it.
After playing this though, I'm half tempted to pick up pt2 and have a butchers at high res mods and stuff.
And then there's the sandbox editor... Love that kinda stuff.
That reminds me Petey i can run my memory up to 1719 on stock voltage. I thought things had changed regarding that but they haven't. I can probably go a little higher but i think 1750 is as far as i can go roughly with the memory at stock voltage.
What does it need for 1900?
With mine, 1800-1900 on stock, depending on the application. 1.619v does 1900 on everything afaik.
Haven't made much of an effort to get it any further, but I'm not sure it wants to tbh.
1823 = 350Gb of bandwidth. Diminishing returns beyond 1823 i found. I used to need around 1.625v for that. I bench as high as 1875 but have not pushed it any further. 24/7 though i like to leave the memory at stock voltage so tend to keep it 1719 or lower.
What was the highest clocks you could achieve before fitting one of these coolers fella?
If you do, I'd definitely recommend 2mm tape. The 1.5mm that I tried (same as the stuff you ordered) left next to no vrm indentation.
Oh, and it's up to 1mm shorter than the Enzo sinks.
Actually, I wonder if you could pack out the gap with thermal glue?
It's a bugger because of it's elasticity.
Thanks matt,
Yikes sleeping dogs makes my card toasty -
The only reason my temp is low in this pic is because the bench ends quickly, playing the game with Extreme AA pushes the VRM 1 into the high 90s sometimes even 100+! In crysis 3 it gets to 90c, BF3 80c but this game is one whole other level.
I bought this heatsink, it's still in shipping but this is what i hope to do
Basically bend the fins sideways so i can get enough clearance for it to fit under the accelero. If that doesn't work then i'll have to improvise. My VRM temps are pretty bad now, they only get better right![]()
If i had a dremel i'd do what tommy did in a heartbeat but unfortunately i don't have anything that can cut my cooler the cleanly. I wonder though, if either my kitchen scissors (they are beastly), nail cutters can do it.
The Gelid should be buffed down/sanded flush with the rest-at the screw point, then it will be a perfect fit on the vrms(that's what tommy would have done given the chance-sniff sniff, pass me a tissue boys, I'm welling up now) and will give even more clearance to the cooler.
I never got around to using it mate. I'm happy to pass it back if you want it
I did manage to lose two of the little black washers though![]()
