Well for starters either work with dumbells or barbells.
You don't need barbell bench press followed by barbell incline press followed by DB bench presses.
did not think of it that way.. taTo put it nicely it's crap. Way too much overlap and too much isolation and you don't really want to be doing deads and squats on the same day if you really want to push on either of them.
Nout wrong with doing barbell and db work
i've been trying to put a routine for my self, here's how far i got and i think it looks alright, what do you lot think?
now i know this may look like a mess to some, and set/rep ratio may look bad but that is the reason why im here, im trying to get a good routine going so any help is appreciated!Code:Tuesday - Chest and Triceps machine butterfly - 10x3 Barbell Standing Overhead Triceps Extension - 10x3 Dumbbell Standing Triceps Extension - 10x3 Tricep Dumbbell Kickback - 10x3 Bench Dip - 15x3 Barbell Bench Press - 10x3 Barbell Incline Bench Press - 10x3 Dumbbell Bench Press 10x3 Dumbbell Fly - 10x3 Decline Crunch - 10x3 Thursday - Biceps and Shoulders Barbell Shoulder Press - 10x3 Dumbbell Lateral Raise - 10x3 Dumbbell Front Raise - 10x3 Barbell Shrug - 10x3 Barbell Curl - 10x3 Dumbbell Alternate Bicep Curl - 10x3 Alternate Hammer Curl - 10x3 Dumbbell Concentration Curls - 10x3 Alternate Incline Dumbbell Curl - 10x3 Decline Crunch - 10x3 Saturday - Back/abs/legs Barbell Full Squat - 10x4 Leg Press - 10x4 Leg Extensions - 10x3 Seated Leg Curl - 10x3 Barbell Deadlift - 5x4 + 5x120kg+ Barbell Bent Over Row - 10x3 Wide Grip Lat Pulldown - 10x3 Close-Grip Front Lat Pulldown - 10x3 One Arm Dumbell Row - 10x3 Decline Crunch - 10x3![]()
Dem feels when your spotter takes revenge and makes you work for your last rep. FUUUU.jpg
i suppose you're rightdid not think of it that way.. ta
crap? that doesn't really help me put a better routine together, the reason why deadlifts and squats are on the same day is because my squatting is really bad due to sprained ankles/ripped ligaments, my stability is rubbish so i need to work my way up from low weight to higher..
Just do a beastly chest or upper body workout. Don't be a phaggot.
Eurgh.
Achilles Tendonitis, (well, that's what it seems to be), has now put me out of the gym for another day. I've been foam rolling my calf and icing it, but it's really starting to annoy me right now. Very tempted to go to the gym and just bench in the meantime, as I can't really DL/Squat without quite a bit of pain, although I guess I could do some pull ups as well.
kd
This.
KD: biceps, lats, traps, right bicep, tris, rhombs... the gym is your oyster.
I spent five weeks doing beach weights with a torn adductor back in October, so stop moping.![]()
It's just a bit of a weird routine compared to my normal 'squat/dl' foundations
Why are you icing it?![]()
A
This is the BEST way to be spotted and I far prefer my spotter to let me struggle a bit. I feel cheated when a spotter thinks they have to pretty much take the weight off you.
What do these things say about the mechanism for icing's efficacy?Everything seems to says to
kd
Of course, I welcome a light spot and a 3/4 second rep. But a 10-12 second rep is a mean mother ******!
Feel free to not indulge me here, I'm sure you get my point![]()
