If you can discuss things in a civil manner, step away from the thread.
You may want to go for this kind of bundle then.
http://www.overclockers.co.uk/showproduct.php?prodid=BU-145-OE&groupid=43&catid=2512&subcat=2519
If you don't overclock it comes pre-overclocked with warrenty. There is reason to think games will use better threading as the new console have an 8 core cpu. The bundle linked has a 6 core cpu so should last you ages. Leaves you £1k to think about the rest. I spent a lot on my machine 5 years ago and its still enough for todays games. All i need to change now and then is the gpu.
I am actually going for that board but with the 8 core i7
There isn't an 8 core i7.
What 8 core i7? I never knew they did i7's in 8 cores. I see xeons with 8 cores.
Lol I don't know what I'm talking about the link below is what I'm getting,
God help me when all this comes through the door Saturday
http://www.overclockers.co.uk/showproduct.php?prodid=CP-395-IN&groupid=701&catid=6&subcat=1672
Yea the bundle i linked has that cpu overclocked. Its 6 cores with 12 threads. Good choice imo with your budget.
Does the bundle come with a cooler?
Don't get an OEM one, get a retail one instead;
http://www.overclockers.co.uk/showproduct.php?prodid=CP-392-IN&groupid=701&catid=6&subcat=1672
You only get 1 year warranty with OEM, but 3 years with retail.
If your thinking about going 2560 x 1440 then Titan would be worth it.
I'm ordering a new IPS 2560 x 1440 tomorrow. Just deciding which one? DGM IPS 27" is at the top of my list because it's so damn cheap everywhere.
Dont do it. I had 3 and they all went back. Poor build quality and I would hang on and spend that little bit extra for the dell u2713hm. Anti-glare isnt as noticable and the warranty is second to none (swap on doorstep for a new one)
