Well that is ok then as long as you dont think your 7850 will last for the whole time the PS4 is out because it is similar to PS4 graphics card![]()
anandtech said:I've confirmed that there are 8 Jaguar based AMD CPU cores inside the PS4's APU. The CPU + GPU are on a single die. Jaguar will still likely have better performance than the PS3/Xbox 360's PowerPC cores, and it should be faster than anything ARM based out today, but there's not huge headroom going forward.
No doubt.A card such as a GTX670 or 7950 would probably be OK .... but it is not the same for PC and consoles you cannot compare them directly because of things me and other people have already mentioned in this thread.
No doubt.
Either way I wont be buying a PS4 until GT6 comes out![]()
But I bet when Quake 3 first came out, it was 20-30 FPS all round.
I am at that horrible stage where I now need an entire PC upgrade but do not have any money.... I don't think my Q6600 and 5870 is going to cut it and there is not much point upgrading the 5870 until I have a new CPU bad times :S
PS4 gpu is only 1.84tlfops ? about the same as a 6870![]()
overclock your cpu
A 2gb 7850 runs 1.75 TFLOPS so the PS4 gpu is more like an overclocked 7850 or an underclocked 7870.
Plus running in a closed system it's far more capable.
Are we definitely getting a standard 1080p on the new consoles? If not I might be put off... I'm already considering upgrading to 1440p because 1080p isn't doing it for me.
at least 2 dev companies have said they are sticking with upscaled 720p on next gen consoles and also sticking with 30fps, epic(gears of war) and capcom.
Hopefully some devs will do some nice 60fps 1080p games so console gamers can witness fluid graphics.
720p up-scaled at 30fps seems pretty disappointing considering the ps4 is a decent leap from the other consoles
