- 16 Jan 2003
- Nottingham
Only bought it as its £13.85 & hoped Capcom had launched with the console patches integrated (they did not bother) I knew it would be a steaming POS & I was right its also the unpatched version 2 patches behind the console versions as you need to perform all QTE's (there are way too many) & cannot adjust the FOV properly so the camera is way too close to the player.
I'm guessing you discovered you can enable the QTE skipping and change the FOV once you finish the first part of the game right and get a proper main menu?
