- 22 Jul 2012
- London
PICS ADDED:
So, the arch-aircooler finally gets around to dipping a toe in the wet stuff
I honestly don't need to improve my CPU or VGA temps or anything, it's just that building a loop looks like a lot of fun and I can't resist any more, so here goes!
So far, we have:
- Koolance 380i Cpu Block
- EK FC7970 Block + Backplate
- 2x 240mm Alphacool Monsta Rads *giggle*
- Phobya 150 Reservoir
- EK D5 CSQ Pump top
- A bunch of EK compression & rotary fittings.
Soon to come:
-D5 pump
-Tubing/coolant etc
-Misc stuff + a few more fittings
Stay tuned to find out how this all gets shoehorned into a Corsair 500R and expect plenty of pics
EDIT:
Full WC component list
-2x 240mm Alphacool Monsta Rads 360+240 Monsta Rads
- EK D5 Pump top
- XSPC D5 Vario pump
- EK 45° + 90° rotary fittings
- EK compression fittings
- Koolance VL3N-FG Quick Release Connector Female G1/4
- Koolance VL3N-M13B Quick Disconnect Male Barb for ID 13mm (1/2in)
- Phobya Noise Destructor V.1 (the pad under the pump)
- XSPC UV green 7/16 5/8 tubing
- Mayhems X1 clear coolant
+ A couple of LED G1/4 lighting modules and a twin 5mm white LED cable for the reservoir.
Looked great with clear coolant, but the blue dye killed the lighting effect
Edit: Turns out the LEDs just went bad..
Thanks to Tonester (GPU block/backplate, Scythe GT's and rotary fittings), Space Monkey (CPU block and pump top) and Fireisdangerous (Most of the compression fittings) for your MM bargains that made this possible
So far, we have:
Soon to come:
EDIT:
- EK D5 Pump top
