**MSI HD 7950 TWIN FROZR III BOOST EDITION REVISION2 IN STOCK!!**
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
Our replacement stock of the MSI HD 7950 Boost cards have arrived, I've test a couple of these and am glad to report they do not have the 100% fan speed issue when GPU temperature goes above 58c:-
MSI HD 7950 Twin Frozr III Boost Edition 3072MB GDDR5 PCI-Express Graphics Card **NEW REVISION** @ £239.99 inc VAT
Leading global mainboard and graphics card maker MSI today announces the release of the R7950 Twin Frozr III/OC graphics card. This graphics card features the latest AMD 7950 chipset with 1792 stream processors and 3072MB of 384-bit GDDR5 high-speed graphics memory. The greatly improved overclocking potential and stability increases overclocking performance up to 37.5%! The highly acclaimed Twin Frozr III thermal design with 8cm Propeller Blades fan setup for 20% more air flow and 8mm SuperPipe technology is used for cooling. Fan noise of just 30dB at full load provides gamers the most silence user experience, while MSI Military Class II components are used to give the highest quality and stability. For gamers seeking overclocking potential, cooling and stability, the R7950 Twin Frozr III/OC graphics card offers the perfect solution! This Boost Edition has an impressive base clock of 880MHz, but even more impressive is the Boost clock of 960MHz out the box.
Full Specifications:-
- MSI Twin Frozr III Dual Fan Heatpipe Cooler For Maximum Cooling Potential and Low Noise
- Memory: 3072MB GDDR5
- Memory Clock: 5000MHz (effective)
- Memory Interface: 384-Bit
- Shaders: 1792
- Bus Type: PCI-Express 3.0
- Display Connectors: 2x Mini DisplayPort, HDMI, DVI-I
- Crossfire: Up to 4 Way Support
- Warranty: 3 Years
**Latest Revision with 100% fan problem fixed, now PWM fan control works and the end-user can also use manual fan control**
Only £239.99 inc VAT.
ORDER NOW
A truly incredible card, we found the cards were levelling out around 64-68c under-load which had the fans hovering around 50-55% mark which was indeed very quiet. Also manual fan control worked perfectly! :)
What games bundle comes with it?
Tells you on ocuk page,crysis 3 and bioshock infinite.
MSI HD 7950 Twin Frozr III Boost Edition 3072MB GDDR5 PCI-Express Graphics Card **NEW REVISION** with Crysis 3 & Bioshock PC Games
Has there been any other changes to the PCB? I want to be sure I can fit a waterblock to it before buying. The first version of this used 7970 pcb, is this one the same?
If I placed an order at 1:52 pm and choose saturday delivery do I get the package on saturday or not ? Ive receive an email at 4.50pm saying "Orders shipped after 4:30pm on a Friday may not be due for delivery until the following Tuesday". So why I was able to choose saturday delivery at that time and you have shipped 3 hours later ? That's a bit tricky tbh
So does anyone at ocuk know if this card is compatible with the 7970 waterblocks?
Going by the MFR code on the product page it is compatible.
Would hate to order the card and lots of watercooling gear then find out it wont fit! :(
Ask in CS?
I've asked but doubt I'll get a response in there until tomorrow and the deal will likely be up by then.
Have my eyes on a reference based 7950 boost elsewhere so that would probably be a safer bet. OCUK don't sell any 7950 waterblocks so I'd only buy this if it has the 7970 pcb. I like to get everything from 1 store :)
You will get the parcel tomorrow, don't worry.. It isn't worded too well.
