***The Vapers Lounge***
Status
Not open for further replies.
I'm doing ok so far but my mouth gets a bit dry.
Vapeland will have the CE5 clearomizer no wick in soon :) I got to try it.
Is that the steel wicked clearo? I watched a video of someone using them a week or two back. Think the SS type is a CE9 but I'm not 100% sure on that.
Ooo only just noticed this thread, so man vapours out there! I've been useing this one
http://www.vapouriz.co.uk/electronic-cigarette-starter-kits/vapouriz-tank-starter-kit-bundle.htm
Still smoking the odd real one here and there like, anyone know what the closest actuall tabbacco liquid is? I've used a couple and they all taste overly sweet to me. Useing the red bull one atm from the above site and its pretty nice for a change :) Also been looking for a really nice cherry one like the baccy you get in a turkish pipe, tryed the cherry one again from the above site and it tastes like cheap lip balm :S
Just got my first mixing kit from TW after buying premixed for the last 3 months, would you say that 20% is the maximum flavouring I should put in? Made a small mix of 5ml with 15% and the flavour is very weak.
El Cigarillos from House Of Liquid is by far the closest to tobacco flavour. I tried loads and nothing even comes close to that one.
When you first mix a batch up the liquids aren't well mixed. Ideally you want to leave them to sit for a few days and give it a good shake, but you can speed up the steeping process by doing this:
1. Put liquid in sealed glass bottle
2. boil some water and mostly submerge the bottle (try to avoid submerging plastic caps) for 5 mins (I just let it sit in a pan)
3. shake and let sit for another few minutes
4. remove and let cool
5. vape your delicious liquid.
I use 10% and that's plenty strong for me (if the liquid sits for over a week it can taste very strong!), but 15% is fine depending on what kind of flavour you are after. Mix up a 10ml batch and try that technique, or just give it a shake and leave it for a day or two.
I piked up a Vapeonly BCC Mega yesterday: http://www.ivapour-elixir.co.uk/vapeonly.html
It works really well and seems to wick much better than even the Vivi Novas I've been using. It does gurgle a little bit though. Nicely made too.
Let us know what it's like to live with. My only worry with BCC atties is that you might lose some throat hit, and that's just a big no for me. It does look really nice though!
Nice one cheers, i'll get a sample bottle and give it a bash, trying to find one that will help me give the real fags the push all together :)
I get a lot of my juices from here. One of the cheapest and best places around. You can mix the liquid to your exact specification.
Very highly regarded on AAEC and POTV.
Use code AAEC to save some money.
looks good that. I just orederd 10ml of each apple and cinamon, pear and blackberry honey drizzle and very berry cool..all with extra flavour and with shipping it was only £9 (with the discount code) :D
Cheers
Cheers
There are more flavours than that. You can also get 3 x 20ml any flavour for £11.62 delivered. I guess you didin't see the tailor made flavours?
I'm tempted to try one of the dual coil heads on my nova. Apparently they're a bit of a pain to rewick, but it sounds epic. Anyone had a go with them?
ye..i saw that deals also. But I quite liked the sound of these 'speciality' combinations they have. The deal only applies to single flavours as far as I can see. If these are nice, i will try the standard ones also :)
Me and my bro have just jumped in two feet forward. and each gotten one of these kits:
http://vapourhut.com/Ecig-Kits/Intermediate-kits/VH-Star-Kit
We also bought:
CIGARRILLOS NATURALES 60ml
EDEN 60ml
So hopefully we can throw away the real cigs :)
Since I'm completely new Im kinda confused, with the kit I have bought will I need new Atomisers & Cartomisers??? If so how often and what ones should I buy please?
Thanks
Meds
Hard to be 100% sure how often you'll want to change Atomiser (a carto is just a type of Atomiser) 2-4 weeks is about right for most I'd say. Some are just rubbish and hardly last and now and then one will last ages.
I'll leave suggestions to people that use pre made ones. I use a rebuildable one where I just wrap a new bit of wire on when the old one has stopped working as well as I'd like.
I've been meaning to post about this for awhile but does everyone here know the EU are debating on the Tobacco product directive which if it goes threw unopposed will ban e liquid greater than 4mg / ml (useless for most vapers)
If you are interested in what it is all about UK vapers has all the information you need.
Thanks. Could you suggest replacement cartomisers for the kit I bought please.
Also if the ban goes through does that mean the kit I've just brought becomes useless??
Nope, the legislation would just limit the amount of nicotine in the liquids to 4mg strength (I vape 12mg, so this would bug me). There are a lot of groups opposed to this, and it's a very small part of some big legislation going through the EU. I've been in touch with my MEP's and had some encouraging responses so far. I wouldn't worry about it now though (unless you feel like getting on to your MEP to talk about your opposition to this as well).
As for replacement atties, your kit batteries support pretty much any replacement atomiser out there (it uses what is called an ego connector, which is also compatible with 510 fittings, but they won't look as nice without the skirt sitting flush on the battery). Which is best for you is a matter of personal taste (some have better flavour, some provide a more satisfying "throat hit", some are easier to use etc), but I'm a big fan of these cartomisers
http://www.ecigwizard.com/accessori...a-dual-coil-cartomiser-black-5ml-tornado.html
I usually get a good 2 weeks out of one of those, and they provide a good vapour and throat hit. Just make sure you fill them fully the first time and give the liquid plenty of time to soak all the way through the wick. Refills can be done much quicker though.
You might also like these
http://vapourhut.com/atomisers-cartomisers/tanks/vh-nova-single-2ml
which come with 3 "heads" (the wick and heating coil bit are the bits that wear out and can be replaced in some atties), and you can either buy more heads when those wear out, or for the adventurous, you can rewick the existing ones very cheaply.
The liquids you chose are great, so I hope you like them as much as I do (again, liquid flavours are a matter of personal taste).
Let us know how you get on so we can help you through the initial learning phase and into the awesome bit. :)
Status
