- 22 Jul 2012
- London
A LOT slower...
I just put my WD Blue 500GB HDD into an external dock (Icy Box IB-112StUS2-B) and used a PCI slot eSATA-SATA connected to the same SATA port on the mobo that the HDD used when connected internally and got ridiculously slow speeds.
My Steam library is on this drive and games take an age to load.
I then tried it via USB2 and load times are acceptable, but still noticeably a little slower than a direct sata-mobo connection.
Here are the HD Tune results for each:
eSATA:
USB2:
Any idea why it's this bad? I've tried two different esata cables and no change.
I may just return it and get a USB3 dock/caddy instead if this can't be sorted.
Cheers for any help
eSATA:
USB2:
Cheers for any help
