[TW]Fox;24129238 said:I bought some and it was clearly advertised as 100 RON.
So its only 1 RON higher than regular V-Power? :S doesn't seem worth the effort on their part
Edit: NVM saw the bit about CZ.
Apparently Shell will be launching a pr campaign for the new V-Power in the UK soon.
It's is launched tomorrow the 18th
It is called V-Power Nitro+
There is Unl and Dv versions.
It is 99Ron and no difference is price v the old Vpower
anyone worried it might not work in the car..... you have had it in your tanks for a little while now already![]()
Sow what does the new additive do?
Costs more.
The new additive targets Direct injection deposits apparently.
Simon said:The new additive targets Direct injection deposits apparently.
King4aDay said:Is it not just the new 10% ethanol mix? Thought I heard vpower was switching to E10... I might be confuzzed though.
Ivyforce said:Will check tomorrow but I don't think so.
Ethanol content has not changed in nitro+
Does anyone know for definite if either tesco momentum or shell vpower contain ethanol?
