Caporegime
- 21 Jun 2006
yh they are from IKEAi think they're perfect height as well.
its part of the BESTA range but i got the wall cabinets rather than the actual tv unit in the range as the measurements suited my needs more
i did try putting the dvds in the other way but the bookcase is that deep it wastes to much space.
how low is your couch? or do you sit on the floor? because one of those cabinets is far too small. do you use the metal clips at the back? i had them set up but they just became a pain when adding or removing things from the setup so i just got rid of them in the end.
u shud see what my two liccle monkeys do! I'd be happy if it was just the cupboard handle they broke
(Sorry about the bad phone pic)
