The New Cases Gallery
Here is my build. :)
I normally run the stock fans at 7 volts using the built in controller.
When gaming I keep the front door open to let in a bit more air, I can hear my GTX 680 when gaming above the stock fans, just to try and give you an idea how quiet it is.
With the door closed it does drop the fan noise down quite a bit.
Running 2 140mm fractal fans in the front & one fractal 140mm in the top rear all off the built in fan controller, a H80I with 2 120mm vipers as an exhaust on the rear & 1 140mm viper in the bottom of the case, all the vipers are running pwm off the motherboard.
Hope this helps.
Cheers all :)
When its switched on its not truly silent, just a bit of background noise really.
But I would not put up with something that sounds like a harrier taking off sitting beside me on my desk.
Forgot to mention I have got the windowed version so there is a bit less soundproofing on the inside of the panel but it really does not make any difference sound level wise.
Cheers
With the door closed is it silent then? :)
I'm looking at a HIS 7950 IceQ Boost to go with this in the hope its fairly quiet. I wear headphones when I game so it shouldn't be an issue. I just want it to be silent when its sat on my desk and I'm browsing the internet or watching youtube or sleeping with it in the same room. (Not like that ;))
Sorry just seen your post :) On the reviews I've seen for it they state that they only know its on when the LED flashes on it, do you find thats not the case then? Is it the components inside making the noise?
Yes I sleep with mine too ;) if you put the fans on the slowest setting with the built in controller and close the door there is a slight fan noise but not something that would be really noticeable, my hdd can be heard above the case fans on the slowest setting.
And yes the components do make some noise, you can also cut out some of the noise by not adding a fan in either of the top vents as the blanking plates for them have the same sound insulation on them as what is fitted on the right hand side panel.
Sadly though don't think there is such a thing as a totally silent case :(
Cheers
Changed mine a bit, replaced the psu with a Corsair AX860i with the V2 braided cable kit. Replaced the STX soundcard with a SoundBlaster ZXR and the most costly upgrade was replacing my 7970 with a Titan.
The white is mine, my original ATX components transplanted in to the new shell with m-ITX mobo and 550W modular PSU.
GTX670
Intel i5 2500k
8GB DDR3
Intel 256GB SSD
500GB HDD
Blu Ray Drive
My bro's is the orange one, only four parts bought new from OcUK which were:
BitFenix Prodigy Case
m-itx motherboard (can't remember which off the top of my head)
OcUK modular PSU
Total £190
Blu Ray Drive £70 or sommat
Then got the rest from the MM:
GTX560Ti 2GB model (£80)
8GB DDR3 (£30)
Intel i5 3570k (£120)
500GB HDD (inherited from me as I couldn't fit it in mine!)
Old vs New
Just swapped my rig out of the PC-A71 into the PC-B25F :)
I'm liking the downsize to midi from full-tower but wish the B25F also had a door like the A71 -
