- 18 May 2010
- London
I can binge on these bad boys!!
No....... You might think this is a good idea, but really, NO......I can binge on these bad boys!!
Wrong. You are probably pressing half your bodyweight or something. You'll get more of an "aesthetic effect" from pushing heavier weights, whatever you do it with. Which is not to say you should not be doing the bench. You should. But while you're learning how to do it and slowly building it up, keep up whatever else you've been doing too.Lets put it this way. I am more concerned about the aesthetics than the performance benefits of an exercise. If I am only shifting small weights on the bench, it will still have an aesthetic effect on my chest right?
Dips are fine. Why not add pulldowns too? Even better.I have my mojo back and feel motivated to work out.
In my routine I do one and one only tricep excersise.
This is currently dips. Now I do this twice a week. Should I just stick to dips and perform them twice a week and try to get better at them and eventually add weight to my body weight or do you think it would be a good idea to alternate each session between dips one day and cable pull downs the next?
Are dips the number one excersise for tris? Obviously at my level Im simply looking at add the most gains with what I do.
Word.CGBP as well.
Pull ups: I presume you use an assistance machine? Ditch it, start off with bw reps, if you can't, do negatives.
Once you can do a bw pull up, do as many as you can, when you fail, do more negatives.
Bench Press - I managed my match my PB today at 42.5kg will be overjoyed to get to 45kg, as 42.5kg has always been my absolute max. After 45kg, then 50kg will be my next benchmark.
OHP Is currently at 25.5kg. Will be over the moon at 30kg.
Barbell Curls - Currently at 30.5kg - Goal for the next few months would be 35kg. This would be massive when/if I ever reached it.
I find the PLATE loaded machines can be useful (though not ideal). I don't think it's true to write them off entirely. As part of a generally well-conceived free-weight program, they might in some cases be a worthy addition.If you want a well-developed body, single arm dumbbell rows.
There is no excuse for using machines.![]()
Yeah...Quote:
Wat.
