Caporegime
- 8 Jan 2004
- Rutland
Just buy a DAS6 Pro and do it properly.
I've had mixed results with this (mainly due to my own cackhandedness). One tip I will give anyone is to order extra applicators. They don't give you enough in the normal touch-up pack.
Do the citrus pre washes strip off any wax/sealant/protection on the car?
I use AF Citrus Power and it doesn't strip any LSP.
http://www.polishedbliss.co.uk/cgi-...se-citrus-power-cat2.html#aAFCP0500#aAFCP0500
Apply and rub in with foam pad, leave to haze a bit, buff off with a microfibre cloth.
Far enough! I'll see how it goes today, if it doesn't start raining again.
Today I bought:
- 2 spongs
- 2 buckets
- XL chamois
- 3 different microfibre cloths
- car shamphoo
- car polish
- wax
Excellent!
Ditch the chamois and get a large microfibre drying towel like the one paradigm mentioned.![]()
