anyone else getting an issue wen music just stops? happens through the speaker and headset and both the default music player and winamp
sometime after 2 mins or 15 mins, its as if im hitting pause
Are there any dedicated Google Music apps/widgets that integrate into your home screens? A friend had aa widget on his rooted/custom firmware S3 that you scrolled across 1 screen and were greeted with a full google music widget where you could play from there, scroll through all albums/uploads etc.. and just wanted to be sure, as the seamless google integration is something that I really want to make sure on!
All he said he was using was "play music and play - My Library"
Differences between Exynos and Snapdragon S4's:
http://www.engadget.com/2013/05/06/samsung-galaxy-s4-octacore-review/
Looks like my S3 pouch would fit an S4 almost perfect..
Dimension (HxWxD)
S3 = 136.6 x 70.6 x 8.6mm
S4 = 136.6 x 69.8 x 7.9mm
Dimension (HxWxD)
Pretty sure Google Music has it's own widgets?
I'm no expert but to me those look like some really excellent photos.
Did you have an S3 and have you got a comparison photo of the best you did with that?
Got my S4 arriving tomoz, my sfr contract states I can unlock it for any network after 3 months.
I am coming back to the UK for a wedding next week and have a couple of questions.
A.Is it possible to unlock the S4 yet without paying for the privilege ?
B.What are the risks involved?
Thanks in advance!
what rom are people using? i'm on XXUAMDC and to be honest its laggy hell and has a good few bugs in it... feels very rushed!
Got my s4 this morning at half 7, but its still not letting me ring or text anyone yet, does it normally take a while to activate? do i need to do anything? im on orange.
You did put the SIM card in?
Only joking. It should be instant, check the SIM is in properly.
