A reminder to you guys to unlock developer options and enable force gpu rendering to ensure a more consistently smooth UX.
How do we do this?
How do we do this?![]()
Hi, it is registering on orange, it just wont let me make any calls or send texts, texts fail, and calls go straight to orange answer phone saying something about adding credit or business stuff
anyone else getting an issue wen music just stops? happens through the speaker and headset and both the default music player and winamp
sometime after 2 mins or 15 mins, its as if im hitting pause
Smart listen.
I've somehow managed to delete the call icon from the home screen. Can anyone please help me get it back?
Samsung's 'S Voice' assistant app has improved considerably on the Galaxy S4. In fact, it's worth revisiting if you dismissed it on earlier devices due to slow performance or hit-and-miss speech recognition. On the other hand, if you're not using S Voice regularly, there's a quick, easy setting change you can perform to make the home key just a little more responsive.
By default, when you double-tap the home key, you'll launch straight into S Voice. That means when you press home, there's a very short pause while the phone waits for a second button press. To avoid this and have the home key immediately send you back to the home screen, you can disable the S Voice shortcut combo. To do this, load S Voice, then press the menu key and hit "Settings." Next, uncheck "Open via the home key." That's it -- with the shortcut combo disabled, the home button should respond immediately as opposed to with a very slight delay.
Faster home button response:
Great minds.....![]()
Still not as fast as my s2 though. Which is funny![]()
Have you timed it?![]()
Ordered my S4 on Sunday night after finding a cracking deal on Mobiles.co.uk but now I'm worried they made an error.
Basically, it's an upgrade and I pay nothing upfront and get 'The Works' (unlimited calls/text and 1GB data) for £36 a month. That's less than I'm paying for my S2.....
