Can the LEDs be disabled/removed easily?Bit Fenix Pro Spectre 200mm fits well inbetween drive cages/case and performs well.
Will a depth of 25mm be fine for behind the harddrives?You can purchase the non-LED version here: http://www.overclockers.co.uk/showproduct.php?prodid=FG-063-BX&groupid=701&catid=2331&subcat=2335
I have the filter for the side intake. It does the job but is very pricey for what it is. If I was to do it again, I'd wrap the side mesh in a nylon fine grade material from a UK stockist.
The front one is fine, just needs regular cleaning.
As in removing the filter from the front of the case or removing the material from the plastic and metal shell?
Which one lol?
If its the first then you just push the filter at the top and it pops out of the case. If it's the second one then you don't really need to do that. Just take a hoover to it while it's out or put it under water and dry off.
I bought a dust filter for the back fan as I use it as a intake (h100i with fans on top taking air out).
However I had to take it off 5 minutes later. It is soooo noisy! I think I might have to have a rethink about my airflow but I need to keep my xfire cards cool. Might not have been the case to go with.
