***Official METRO Last Light Benchmark Thread***
30 Mar 2010
Under The Stairs!
13.5 beta2
7950 CrossFire@1200/1500MHz
[email protected]
Total Frames: 8903, Total Time: 168.6174 sec
Average Framerate: 52.84
Max. Framerate: 102.77 (Frame: 7433)
Min. Framerate: 14.35 (Frame: 4)
CrossFire gpu usage ~80%
Total Frames: 8966, Total Time: 169.1064 sec
Average Framerate: 53.06
Max. Framerate: 101.76 (Frame: 7488)
Min. Framerate: 14.32 (Frame: 3)
What can I say?
Stunning Benchmark, stunning gfx, runs great, very well done 4A Games/Nvidia! :)
I was wanting to put a vid of the BM on max everything, until I can find one or someone ups one, this will have to suffice(until someone uploads a video of the mighty Titans crushing MLL BM max everything@1080p;)):
3D SBS version:
3D SBS:
Crossfire is actually working already? I'm amazed seeing as this is a Nvidia game. I'd expect AMD to have a lot more optimization to come for this game. Good stuff either way.
Its not working to full potential or surly gpu usage would be higher? 99% usage would see it sit easily at a 60 frame refresh. I'll buy this tonight and run some tests on 7970 cf at the same clock speeds :)
Downloading it now on steam but will not be able to run it until tomorrow.
Cry havoc and let slip the dogs of war.:D
Wanna see some physx on this baby. It's uses it very nicely indeed!
Still want to play through the first game before i get last light.
Is this a proper in game benchmark.
Yes.
Crossfire is actually working already? I'm amazed seeing as this is a Nvidia game. I'd expect AMD to have more a lot optimization to come for this game. Good stuff either way.
It's not at it's full potential yet, but it's working well for 0day performance nonetheless.;)
Read this before you buy it.;)
To run this with a VPN:
1. Connect to your VPN of choice
2. Unlock/run the game
3. Quit and restart Steam in Offline Mode.
4. Keep steam offline until Thursday.
5. Enjoy the game.
Manju on his high clocking 670 SLi is pulling more or less the same numbers with PhysX!:eek:
Again, well done 4A and Nvidia, the first time in-well forever:p Iv'e been gutted with Nvidia performance.:D
Getting some poor scaling with 2 Titans.
GPU usage sits around 75-85% unless you put SSAA on & then it jumps to around 85-90%
Don't understand the use of SSAA here either. Why not offer some of the less computational methods? They know its going to be a system killer because of the poorly optimised engine so why make it even harder to run?
Ran the bench and quite impressed. I forgot I had my CPU at stock, so re-ran them with the CPU back at 4.625Ghz (curiosity more so). It seems that this game can bottleneck a 3930K if it isn't overclocked.
1920x1080 CPU/GPU @ stock
1920x1080 CPU at 4.625 GPU @ stock
5960x1080 CPU/GPU @ stock
5960x1080 CPU at 4.625Ghz GPU at stock
I am very impressed with the PhysX effects. Good work and I look forward to having some spare time and getting stuck into this game :)
Wow looking at those with the gpu stock and cpu both stock and clocked this game looks really heavy on the cpu. 29fps avg with both stock from two ultra high end components is astonishing!!
Might have to dial down the aa for 120fps :p
I enjoyed the first game, though I did own it for around 18 months before I actually had hardware to do it justice.
Edit: derp, didn't look at resolution :p
Simplygames version is the limited edition for £21.99. I have just redeemed it on steam and will report back with sli 670 performance benchmarks if I can unlock it.
Didn't realize it had a benchmarking tool; just ran it myself here are some results for SLI 680s
This is everything maxed out apart from PhysX.
And this is the same again just with SA disabled.
If anyone want's I'll run a PhysX one later just off now.
