just done a bit of testing and it appears the source of my fps drop is view distance.
any fix for this ?
any fix for this ?
Buy a better graphics card or turn down the settings.
Why not respond to the post that was actually trying to help you?
he clearly hasnt read my previous posts.
I have done.
Don't get your handbag out just because i'm telling it how it is. The game is more demanding than people think.
You have 3 choices:
1. Overclock the GTX580
2. Dial down the graphics settings
3. Sell the GTX580 and get a better card.
I wouldn't say the game is demanding as I run it fine on my 6970 but your 2nd point has hit the nail on the head I imagine.
I have done.
You have 3 choices:
i appreciate you assistance but i don't think the answer is to buy a new gpu.
gpu usage is around 40-60 % .....
unoptimized is more appropriate.
its a dx9 game that doesn't even utilize MSAA.
a modern toaster should do the trick
What CPU do you have? Maybe you are CPU limited?
It's more demanding than a lot of people think when you've got the settings up.
Do you even understand what "changing settings" means or did you skip over that due to finding it too confusing?
You might be better suited with a console.
