Just found this waterblock review
http://www.overclock3d.net/reviews/gpu_displays/xspc_gtx_titan_waterblock_review/1
I've tried both the XSPC one and now the Aquacomputer one and they perform pretty much exactly the same, both good blocks.
Probably the Aquacomputer one because of the clear top, should look nicer with the backplate as well although i liked how the XSPC one covered the whole pcb.
http://www.hardocp.com/article/2013/04/29/nvidia_geforce_gtx_titan_overclocking_review/1
A good article here on the gains that are achieved with overclocking. Very impressive.
Tried out the T.I. bios earlier out of curiosity, was good and and had constant speeds without fluctuating but flashed back to stock now.
I need waterblocks badly.
I tried out a few different bios versions. One of my cards would only go to 1124mhz no matter the voltage though. I keep them on 1110 just to be safe. I was hoping for closer to 1200mhz with a 1212mv bios but it wasn't to be. Even at under 40c![]()
I also couldn't make 1200Mhz. 1196Mhz iirc was the highest bench I could get.
You should have a go at that physics bench thread you started (Fluidmark I think it was), using drivers 320.00. On a single Titan it is possible to run a clock speed well over 1200mhz doing it. I even managed to overclock the Titan higher than my GTX 690 for that bench. Sadly those sort of overclocks don't work on any other benches.![]()
I wish I had never started that bench..... I hate it![]()
