I have found the following the best for achieving a close/identical experience to stock android...... but better (in some areas anyway!)
stock android keyboard
stock Alarm clock
Stock SMS app or sliding messaging
Dialer with this theme
Stock calendar
stock camera & Gallery
Nova launcher prime with the built in stock android icons
Lock screen (can get the stock lock screen theme/UI) or this
Stock (CM10) calculator
Multi-tasking window
Then there are apps to replace the notification bar i.e. omega, status bar +, super status bar, however, they are a bit buggy!
And everything to do with sense, touchwiz is either disabled or hidden via nova
Not to mention quality isn't as good either!
