Thanks for the comments guysI fixed the fans and changed the direction of flow within the waterblock.
I'm currently getting high temps at 4.6ghz though... Much higher than anticipated!
Can anyone offer any assistance?
well ive now resat the waterblock for a 3rd time without any drop in temperatures.
I use a pea sized amount of MX-4 spread using a stanley blade for fine even distribution. i couldn't apply more than usual this time as i ran out having applied it 3 times![]()
Brilliant job!I run a multiboot hackintosh in a skeleton, but this just looks the nuts! Well done mate, you should be proud![]()
Don't spread it, you can trap air bubbles that way. Let the block do the spreading.
ohh i didnt know about that, i always thought you had to spread it :O
How did you cut the side panel btw? Jigsaw or dremmel? I want a window in my G5 but haven't found anywhere local that can laser cut 3mm aluminium.![]()
Looks great job well done. Don't think I'd be able to do this myself ^_^
That is a big drop!
Looks like you have the rad fans drawing the heat off the rad into the case?
have you thought about adding another fan... for exhaust?
Ace build log, Where has this been hiding?
Those temps are looking a lot better now you have de-lidded the chip.
I really didn't think that your temps would drop that much! I would be too scared to de-lid my CPU.
Very pretty build mate! and nice temps!
Looking awesome bud, really really keep thinking about de-lidding my 3770k :-/
