Stoosh - contact Amazon about the price drop, they should refund the difference.
Really? They would do that? Mmmm I'll give it a go, if you don't ask you don't get!
Thanks Mate
Root
If not,
Install Nova launcher
Go to manage apps - disable/uninstall all apps you won't use
set font to tiny
turn of multi-window in display settings
install swype keyboard
just a few pointers.
Running an EE S4 with their latest ME2 rom. Anyone else notice that Google Music player keeps running by itself? or am I just doing it wrong and inadvertently selecting something when I unlock the device?
Google Play Music's uses a service in Android (services are background processors, bit like windows services without the privileges), might be this.Yes mine does that to. Not even touched Google music either.
Thanks Mate![]()
is rooting same as S2? or is it done differently on the s4?
cheers for the pointers too looking forward to playing with it tomorrow![]()
Could be a ROM thing - which rom you using please dude? I'm on ME2 (EE)mine doesnt do that lol
If the difference is over £10-15 within 14 days I think. Deffo worth a try, and try and get a female rep on the line![]()
Stoosh, you had your s4 for less than 7 days right? If so, just say you want the price difference refunded else you'd just end up returning under DSR and purchasing at the new price; it's more hassle for them so they'd just refund the difference. I've had this happen on a few items purchased from Amazon.
Hope this helps
phew! - thought I was going nuts and it was just me
Not sure why it runs as I don't listen to music ever on my phone. It's wierd because it happens each time the screen turns off, switch it back on and its there in processes.
If all else fails with what Kona suggested with a refund of the price difference then I'll go your route. Mate you're a star! Why didnt I think of that? I've had the S4 for 5 working days coming up tomorrow.
Will give it a go. Both kona and you have been extremely helpful. Thanks goes out to both of you.
Blimey!![]()
No that's a price drop
I should've waited a little while longer!![]()
No worries mate, let us know how you get on!
ME2 on tmobile. I use play music fairly regularly but i've not had it start playing on its own![]()
Aaargh! Its cheaper now! Must resist urge to click order![]()
