- 25 Nov 2011
- The KOP
I upgrading at the end of the year and in no rush to do so. So I fine with releasing close to BF4.
What are you talking about?
I don't what it is. And what difference is it to you that I come around to your way of thinking?
20nm or 28nm it does not make a blind bit of difference to me as long as its a worthwhile improvement on the 7970.
Dat aggressiveness
Dat aggressiveness
Easy Tiger...
I had a debate with you about 20nm and 28nm and I was sure they were releasing on 28nm but you insisted that it was 20nm. I can dig it up if you like? I even agreed that I would like to see 20nm purely to buy one.
The difference to me about coming round to my way of thinking was a simple question...No need for the hostility. Will you be getting the 9970 then if it is a big improvement on the 7970?
Not half as aggressive as Gregster is behaving around the forum right now, again.
Volcanic Islands is listed on AMD's roadmap as 20nm, AMD said they would be available late 2013, I don't know if October is as late as they meant.
Who knows, if they can get 20nm out that early then great, if not then a good GCN 2.0 is also very welcome, AMD change their minds more than I change my socks, and Nvidia's GTX 780 move here may well have prompted them to change a few things.
See this is where the confusion comes in.
Gibbo's said they've not laid back, their next GPU is ready.
Which doesn't compute, as it'd have to be 28nm for it to be ready, which would mean waiting to launch it is waiting around, as it only lessens the time to 20nm.
Or it's ready bar TMSC and they're waiting on them, which is still waiting around.
I don't see how it's possibly good for business when there isn't a choice to go AMD if you want better single GPU performance, as your only avenue is Nvidia.
Also, it's not really anything to do with changing minds, they can't radically change and release in months, it takes time.
The only better option's nvidia have cost £550 upwards. I doubt amd are losing to much not competing at this price point.
And people are buying them regardless of the price point.
Dat baiting
It's Nvidia though and they will probably sell not to bad. I doubt Amd would see the same kind of sales.
Dat baiting
Huh?
Is that aimed at me?
Perhaps AMD is trying a wait and see approach,to see what the GTX770,GTX760TI and GTX760 look like first,before releasing their cards.
Nvidia did the same for the GTX600 series and it worked well for them.
Here they are saying that AMD's next will still be based on 28nm - http://translate.google.com/transla...-and-hello-volcanic-islands-05122013/&act=url.
Taking all of these leaks with pinch of salt..
Good find.
I didn't think they were ready to jump to 20nm just yet but was hoping I was wrong.
Maybe the fact that TSMC are working on 20nm got everyone excited but I believe it is solely intended for Apple at the present time and AMD/Nvidia to follow?
http://www.xbitlabs.com/news/other/..._Is_Ahead_of_Its_Own_20nm_Roadmap_Report.html
I very much doubt it will be on 28nm, that would give it a 750mm^2 core.
They use the same slide and came to the same specifications conclusion, and then said blanketley its 28nm, not 20nm.
The slide does not indicate what the process is, but I think most sensible people would and have come to the conclusion that it must be 20nm, for 28nm would be impossible with those specs.
The first part I can understand, but then releasing in October is a little long of a wait.
Nvidia launched 6XX pretty soon after the 7950, about a month after.
