Drill round them with a holesaw cutting bit, then you can pull up the plywood and get at them properly. Either pull them out, cut them off or bang them down out the way.
NO
Hard removing them, need a good long crowbar to pull them out, as said earlier , I use same method, it's easier, then cut them off with hacksaw, small grinder & hammer flush if needed.
Be careful, might have pipes, cables notched in close to top of joist.
Cheers guys, I'm not looking forward to this at all, middle age has cruelly depleted my mojo and resilience for hard manual labour
Don't I know it.
Wait until you hit 50.
Removed 150mm reinforced concrete roof last week, & I felt all my 50 years.![]()
Yes, Bahco nail puller.
I thought "angle grinder" was the answer to any DIY question![]()
These look good but eye watering price
True, worth their weight in gold though. Got one to redo the house with, and its one of my most loved bits of kit!
