is there a tool/easy method to remove nails from plywood floor
22 Jun 2004
South Scotland
On inspecting plywood floor that I need to rip up I find it is nailed down with loads ring shank nails , this looks like a nightmare task, any methods/tools etc that might ease this lol?
Drill round them with a holesaw cutting bit, then you can pull up the plywood and get at them properly. Either pull them out, cut them off or bang them down out the way.
NO:D
Hard removing them, need a good long crowbar to pull them out, as said earlier , I use same method, it's easier, then cut them off with hacksaw, small grinder & hammer flush if needed.
Be careful, might have pipes, cables notched in close to top of joist.
NO:D
Cheers guys, I'm not looking forward to this at all, middle age has cruelly depleted my mojo and resilience for hard manual labour
long crowbar or prybar would be my suggestion, if you dont have one to hand the biggest flat headed screwdriver you have sould do. Work the end around each nail gently lifting
Crowbar and for the persistent blighters I used my Bosch multi-tool with saw attachment
Got the pleasure of ripping our bedroom floor up shortly - seriously not looking forward to it but makes the world of difference once done and some good quality boards down (screwed in!!!)
Replaced a floor in the bedroom here last year, I took the opportunity to lay some 200mm insulation I got off Freecycle between the joists, certainly cuts down the noise.
Still have enough insulation stashed away for the other bedrooms & landing later this year.
Yes, Bahco nail puller.
These look good but eye watering price
True, worth their weight in gold though. Got one to redo the house with, and its one of my most loved bits of kit!
Darn expensive that Bahco nail puller, I make do with my48" Roughneck Wrecking Bar T Type & a Roughneck Gorilla Bar 48".:(
http://www.lbsbmonline.co.uk/product-details.asp?Auto_ID=20341&gclid=COjztKjI4bcCFXMPtAodomQAdw
I purchased a 14 in gorilla bar today in anticipation, I must say I`m impressed, so much so I might purchase a bigger one. Pulled loads of nails out tonight after work.
Nail frequency :-(
Vanquished nails!
